kz1300 banner
ZN1300 Fuel Filter Replacement
  • rayserra
  • rayserra's Avatar Topic Author
  • New Member
  • New Member
11 years 4 months ago
#5973
Is there a replacement fuel filter out there?
Maybe another type that people have had success with, or procedure for cleaning the old filter.
Thanks.
  • biltonjim
  • biltonjim's Avatar
Re: ZN1300 Fuel Filter Replacement
#5988
The original appears to be still available. CMSNL list it, and MCG in Germany.
  • Milletrecento
  • Milletrecento's Avatar
  • Junior Member
  • Junior Member
11 years 4 months ago - 11 years 4 months ago
#6076
I can't find them now but I know I have seen some similar to stock on eBay. Some searching would probably result in something that would work. There are several that are similar enough to it as well at regular auto parts stores. Purolator for instance sells part number F44804 which I was going to run but went for a regular 180 filter that was in stock.
Last edit: 11 years 4 months ago by Milletrecento.
  • trikebldr
  • trikebldr's Avatar
#6083
I wouldn't get too wrapped up in getting something that fits perfectly. If it fits and has the right inlet and outlets, it's good! Since it is before the fuel pump you don't have to worry about if it will handle any pressure.
  • Milletrecento
  • Junior Member
  • Junior Member
#6086
Yea he makes a good point too. Some filters will work easier than others but if it works it works. I wouldn't worry much about it besides finding one that you can make work. Also since no one has said it yet don't bother trying to clean the one on it as they are not reusable.
Moderators: scotch
Time to create page: 0.197 seconds
