kz1300 banner
which fuel
  • bassie20
  • bassie20's Avatar Topic Author
  • Senior Member
  • Senior Member
which fuel
10 years 11 months ago
#8250
here in europe we have mostly 95 and 98 unleaded fuel, and something called v-power.
which would be best for my z1300 and z1000st?
  • kwak1261
  • kwak1261's Avatar
Re: which fuel
#8253
i run mine on super unleaded. 98ron. theres less ethanol mixed with the fuel.
Z1300 A4 ZG1300 DFI X2
Z1261J GS1000S
Vmax1200 XT500
  • bassie20
  • Senior Member
  • Senior Member
Re: which fuel
#8255
so no additives to compensate for the lead? I was just reading about unleaded being not so good for older engines, I was wondering
what you guys put in.. I dont see it mentioned in the manual.
  • Tonto
  • Tonto's Avatar
Re: which fuel
10 years 11 months ago - 10 years 11 months ago
#8257
Bassie, I always run my Z13 (and Z900) on the highest octane fuel I can get, just to minimise the percentage of ethanol being added: got fed up with repairing fuel taps, replacing fuel hoses etc The last straw came when the tank lining failed on my Z900 due to ethanol :angry:
Re Lead Additives: you should not need to them, as (I was informed by an oil/fuel shipper) all the Japanese manufactures compensated for this on their engines built after 1971.
Last edit: 10 years 11 months ago by Tonto.
  • bassie20
  • Senior Member
  • Senior Member
Re: which fuel
#8258
ok, that helps, I will check if the 98 overhere has less ethanol..
  • tackelhappy
  • tackelhappy's Avatar
Re: which fuel
#8261
Shell V-Power is recognised here as ethanol free in N.A because Shell guarentee it has no ethanol. It is this alcohol that is doing the damage on engines not designed for it's use. Use the best/ most expensive fuel you can buy. A motorcycle doesn't use much.
This article may help.
www.cycleworld.com/2013/07/05/everything...and-your-motorcycle/
OKANAGAN FALLS. BC ,Canada
The following user(s) said Thank You: bassie20
Time to create page: 0.162 seconds
