kz1300 banner
Silicon Brake Fluid. Nomore ROT !
  • strate6
  • strate6's Avatar Topic Author
12 years 6 months ago - 12 years 6 months ago
#705
So,
You spend a load of time preparing your Master Cylinders & calipers to make the bike look as good as new.
They look fantastic fitted............until you add the horrible corrosive brake fluid & it begins to slowly eat your coat of fresh paint.
I am sure i am not alone in having experienced this one !!
Well, there is now a practical & good way round the problem......Silicon Brake Fluid.
This is NON CORROSIVE & does not eat your paint.
Be warned that you cannot mix it with normal fluid, so can only be used in a fresh dry system.
I have had it in my bike all year in the brakes & clutch system & there is no rot or corrosion at all. I wanted to prove to myself it was as good as I had heard & can confirm it is.
This is the brand I used ( Ebay 251368988646 )
Well worth the little extra cost.
Pete F
Last edit: 12 years 6 months ago by strate6.
Time to create page: 0.157 seconds
