Water pump cover 14025-1077
- ckiwi
- New Member
10 years 1 month ago
Afternoon Folks,
Apologies in advance for what seems a stoopid question:
The diagram on partzilla seems to show threads - is this why i can't dislodge with rubber mallet from 1981 KZ1300 to replace mechanical seal?
many thanks
chris h
www.partzilla.com/parts/search/Kawasaki/...ATER+PUMP/parts.html
many thanks
chris h
- stocktoy
Re: Water pump cover 14025-1077
10 years 1 month ago - 10 years 1 month ago
I think you are referring to the recess for the O - ring that seals the cover to the block.
If it won't come out remember its been in there a long time and may need some more persuasion.
the cover is held in by two bolts.
hope this helps
hope this helps
Last edit: 10 years 1 month ago by stocktoy. Reason: added more content
The following user(s) said Thank You: ckiwi
- Lucien-Harpress
I can confirm that that cover simply pulls straight off. However, most of that whole assembly can get really crusty, especially if it's been setting a bit.
Also, you'll get to a point where you've got two or three philips screws that need to come out. You'll almost definitely need some kind impact driver to get them out.
- ckiwi
- New Member
Much appreciated Gents,
I'll persevere and circle back with the result
many thanks
chris h
many thanks
chris h
- ckiwi
- New Member
So i was able to obtain one for a reasonable price & shipping - recommend these salvage yards for hard to find parts:
houstonmotorcyclesalvage.net/
Steve's cycles in GA
Cycles R Us in OH
many thanks
chris h
Cycles R Us in OH
many thanks
chris h
- ckiwi
- New Member
forgot to mention Land's Cycles to HOU too!
Time to create page: 0.184 seconds
