kz1300 banner
1983 z1300
  • Kawboy
  • Kawboy's Avatar
Re: 1983 z1300
9 years 1 month ago
#16509
Dion wrote: opps stepped in that
sorry mate remembered the other weld experience, for some reason thought you had not done alloy.
Dion
No harm, no foul. Being Canadian we have thick skin like walrus. (Got to keep the Canadian myth alive)
The following user(s) said Thank You: Dion
  • McZee
  • McZee's Avatar
  • Premium Member
  • Premium Member
Re: 1983 z1300
9 years 1 month ago - 9 years 1 month ago
#16512
I had a similar problem when I was rebuilding my z1000. I drilled and threaded a hole where the post was and repaired it with a piece of brass rod.
Last edit: 9 years 1 month ago by McZee.
The following user(s) said Thank You: Kawboy, kiwirider
  • scotch
  • scotch's Avatar
Re: 1983 z1300
#16513
Well Done !!!!
I've had some stubborn pins with carbs I've bought and rebuilt. The fear of breaking a pin is a definite concern.. If the pins don't slide out easily I soak them overnight with something like WD. If they don't come out with a push, then I'll heat the post. I have a small butane torch that has a pin-point flame. Some cig-lighters have this feature and would work just as well. A bit of heat along with the pre-soaking has always worked !
Always High - Know Fear !
Last edit: 9 years 1 month ago by scotch.
The following user(s) said Thank You: Kawboy, kiwirider, Dion
Time to create page: 0.196 seconds
