kz1300 banner
1983 z1300
  • kiwirider
  • kiwirider's Avatar Topic Author
1983 z1300
9 years 2 months ago - 9 years 2 months ago
#16155
Hi my second z1300 turned up today all looks ok starts runs fine a bit rattly cold but quiet when warms up .Didn't like starting hot so robbed starter motor from the Scotland bike all starting good now.Hope to get out on the weekend but terrible weather tail end of two cyclones from over the ditch Pete can you stop sending them over lol hope you didn't get any flooding cheers Graham, sorry Ive put it in the wrong category ill get it right one day
2018 Harley cvo ultra 1982 cbx1000 1980 gsx1100 2012 gtr1400 cx500 turbo 1977 suzuki gt750
Last edit: 9 years 2 months ago by kiwirider.
  • stocktoy
  • stocktoy's Avatar
Re: 1983 z1300
#16156
Looks like a nice clean bike congrats
The following user(s) said Thank You: kiwirider
  • kiwirider
Re: 1983 z1300
#16157
Thanks hope to be able to ride this one instead of pulling it apart
  • Kawboy
  • Kawboy's Avatar
Re: 1983 z1300
#16160
Where did you pick this up from Graham? Looking really clean. Someone took care of it. Hope the internals are as good as the externals ;)
  • kiwirider
Re: 1983 z1300
#16161
Brought here in new Zealand just happened to be looking on trade me at the right time its a new Zealand new model not a import its the model i wanted with the big sump hoping Kawasaki had sorted all the problems with them by that model are they a good model any bad faults? Had it trucked down from Auckland.Suspect rattly timing chain cold i will pull the rocker cover and have as look at the plastic idler .Thanks Graham
  • Kawboy
  • Kawboy's Avatar
Re: 1983 z1300
#16164
Depending on the mileage Graham, it could also be either the primary or secondary chains especially if the idle is a little rough. The crankshaft would be bucking and if the chains are really loose, you could possibly hear the chains tapping off of the castings of the lower half of the crankcase. Fire the old girl up and have a listen to the botom side of the motor. I have seen a pic on this site of a primary chain chewing into the web of the lower crankcase.
Time to create page: 0.177 seconds
