kz1300 banner
KZ1300 on the Dyno
  • dcarver220b
  • dcarver220b's Avatar
Re: KZ1300 on the Dyno
8 years 9 months ago
#17256
Pretty coolio! Is that really a 'dyno in a trailer' rig?
  • Kawboy
  • Kawboy's Avatar
#17260
Here's where i would challenge the calibration of the dyno.
  • Ledkz1300
  • Ledkz1300's Avatar Topic Author
#17269
Yes, that was a dyno in a trailer rig :)
Out of curiosity, I went back the next day with my Haybusa. I ended up pulling 160 HP and on 2 of the runs I got about 97 ft/lbs of torgue. which matches the factory specs. On one run I got 160 HP and 160 torgue so I am guessing there is an error in his software on some runs.
Another thing, I was running with no baffle. I think that was causing a lot of my richness at higher RPMs. Sucking way to much fuel through which also lowered the HP.
  • Bucko
  • Bucko's Avatar
#17292
Even with the breakup, that motor sounds so sweet! :)
The following user(s) said Thank You: Ledkz1300
  • Bucko
  • Bucko's Avatar
#17293
My 79 was an oil burner right from the day I rode it out of the dealer's shop. I thought it would get better after it was broken in but it never did.
