kz1300 banner
Damaged liner
  • ogri211
  • ogri211's Avatar Topic Author
  • Senior Member
  • Senior Member
Damaged liner
6 years 5 months ago
#25731
I have just stripped my engine down to check it out, I knew when I got it that the small chain that drives the water pump needed replaced as it had snapped. On removing the barrels it was noticed that the bottom of no4 liner had a big chunk missing where it looks like the snapped chain has fowled. My question is has anyone managed to have a liner replaced, can you get them or would it need to be out another set of barrels, or is it look out for a replacement..
Z1300 A4,Z900 RS,Suzuki GT750A, Buell S1 Lightning, Royal Enfield Diesel. And Z900A4 on the rebuild.
  • Lucien-Harpress
  • Lucien-Harpress's Avatar
Re: Damaged liner
#25732
I had to get a liner replaced on mine. It's entirely possible- the liners can be pressed in and out, and new o-rings can even be gotten. You'll have to pull a good liner from a set of parts bores, though, and then be sure your piston diameter matches up with the new bore.
Then you'll need a decent motorcycle/machine shop willing to swap the bores, then deck the head afterward. In short? It's doable, but involved.
(I've got an old bore set lying around from when I did it. There's at least 4 bores that are probably decent you could use, but shipping wouldn't be cheap. That sucker is heavy. Let me know what you think.)
The following user(s) said Thank You: ogri211
  • Kawboy
  • Kawboy's Avatar
Re: Damaged liner
6 years 5 months ago - 6 years 5 months ago
#25733
Another option- There are companies like L.A. Sleeve that specialize in cylinder liners (sleeves) and can reproduce a sleeve for you. Might be worth an email.
www.lasleeve.com/
www.lasleeve.com/info/contact-us
I have heard that if the cylinder block is placed in an oven at 300-325 F and left standing upright to heat soak, the liners will fall out ( or maybe better said, the cylinder block will fall down leaving the cylinders disengaged from the cylinder block.)
Last edit: 6 years 5 months ago by Kawboy.
  • ogri211
  • Senior Member
  • Senior Member
Re: Damaged liner
#25736
Thanks for the input I'm thinking the way to go is to replace the liner with with a new one if it can be got or made I have been offered another engine but would rather stick with the one I've got as I know it is a low mileage one and apart from that small chain snapping it seems to be in very good condition if I got second hand bores I would probably be looking at new pistons and 6 rebores not a cheap option also my bores have such little wear you can still see the home marks I will ask around I am a member of several forums in the U.K. To see if anyone manufactures them.
  • ogri211
  • Senior Member
  • Senior Member
Re: Damaged liner
#25737
I have managed to press out the liner no problem and I have located a new one from Sweden which I have bought for £100 including delivery , also I can get the orings from Z1300.de, so it looks as if I am sorted OK thanks for the input.
