Out in the cold
- PaulD
Out in the cold
4 years 3 months ago - 4 years 3 months ago
Out on the beast today, bit of a false start as she only fired up on four cylinders After much cursing and swearing and as I couldn’t think of anything else I tapped the float bowl on the offending carb and all was good. Did 60 miles and apart from being a bit “fluffy” when pulling away and the idle being a bit lumpy she ran really strong. I’m hoping balancing the carbs again will cure that. Really enjoyed the run out despite the bloody cold.
Attachment not found
Last edit: 4 years 3 months ago by PaulD.
- mizztheman
- Elite Member
Re: Out in the cold
Hi Paul,
Good to see you’ve got her out on the road. Too cold for me.
The following user(s) said Thank You: Bucko, PaulD
- PaulD
Re: Out in the cold
4 years 3 months agoHi Paul,
cheers Martin, I’ve just finished rebuilding my spare set of carbs so I’ll get your cleaning tool back to you asap. Just a few niggles to sort and some cosmetics that are sending my ocd into overdrive then I’ll be happy.
- dcarver220b
The following user(s) said Thank You: PaulD
Time to create page: 0.170 seconds
