Another KZ1300? How many is enough?
- dcarver220b
Re: Another KZ1300? How many is enough?
1 year 10 months ago
Well, she's going to take some work. But she has good bones. Tank and fender, cowl will need repaint. Couldn't open gas cap, stuck. Sprayed with WD40, no happiness. Learned from another KZ don't force the key. Deal with it later. Custom seat was actually comfie. Front brake cylinder is bound up. No lever. Would not touch it anyway as caliper pistons would probably not release. At least she's a 'roller'.
Bob finds a 1973 Thomas Map in the Krauser bag. Wow. Bags. My other 79, the one I bought, has Krauser bags and mounts. But the bags are broken.
Fairing is Saeng.
That's one big piece o plastic. Bob says the outer edge illuminates when headlight or turn signals are on? Don't remember.
It was hot, and somewhat humid for the phaat boy. Was sweating through t-shirt and starting to feel miserable.
Don J and I felt like American Pickers. We had to drop big-assed boxes full of treasure from the rafters through small openings. Looking at the Saen from this angle... If I cut it down just a bit..
That might work, as Allen Millyard says, 'Perfectly'!
Been awhile since that door was opened!
Fairing is Saeng.
- dcarver220b
Then the grind home. LA traffic on Saturday. What a broken transportation system.. Just Sayin'. I should travel to LA every year to remember how lucky I am NOT to live there!
Home, some pics of bike on trailer.
All in all, in better shape than my other 79 when the restoration started.
Tank has small surface rust spots. Hoping it's external not internal rot going through.
Mufflers.. Not sure if new chrome job is possible.. will find out. Would love to keep them if possible.
- dcarver220b
Krauser bags.
I guess I have a kz1300 addiction.
Pull the swing arm, powder coat it?
S&W air shocks. No idea if they will hold air. Given modern non-air shock technology, these will most likely be replaced.
Less than 17k miles on engine. She's worth saving.
- dcarver220b
I imagine the tank is full of rust and carbs need be rebuilt. This time will rebuild myself, as WildGeorge Carbs was a bit uh......
Radiator fins look good.. but what's inside?
All the typical stuff. Calipers, master cylinder, brake lines, tires. Bike is hard to push, so pistons are stuck.
Front fender rust. How bad is it? Time will tell.
So there it is. Another KZ1300 to save.
More later. What the F did I just do?
- Ted
I like the look of the turn signals in the fairing.
You can buy mine in 5 or 10 years, too.
1981 KZ1300, '98 Suzuki GSF1200S, Honda CL360, Honda CB350G,'11 Honda CBR250, '75 Honda CL360, '00 Honda XR100R
Speak softly and mount a fast bike.
The following user(s) said Thank You: dcarver220b
- dcarver220b
1 year 10 months ago...and the PO said the outer edge of the fairing glows when headlight or turn signals are on? LOL. Might be distracting.I like the look of the turn signals in the fairing.
Time to create page: 0.167 seconds
