kz1300 banner
Lifting and Jacking with motorCycle jack
  • jftman
  • jftman's Avatar Topic Author
  • Junior Member
  • Junior Member
1 year 6 months ago - 1 year 6 months ago
#33181
I know the center stand will get the front and rear tires off the ground with a little ingenuity.
I decided this year to give the tires a rest, and bought motorcycle jacks for each of my 3 motorcycles.
i can not find info in the manual and looking under the bike and looking at the jack, Ummmmmmm?
A small bit of frame tubes are there and there is some piece going across that is a little lower too.
Can I get something in combination with the jack? Or maybe lift it just right with no adapter?
Neither tire will be taken off, just here in NY it is winter weather I am facing.
Last edit: 1 year 6 months ago by jftman. Reason: Spelling
  • biltonjim
  • biltonjim's Avatar
Re: Lifting and Jacking with motorCycle jack
1 year 5 months ago
#33329
On page 121 of the factory repair manual, the section dealing with removal of the front wheel  shows a jacking point on the underside of the engine.
  • jftman
  • Junior Member
  • Junior Member
1 year 5 months ago
#33344
How will the traditional motorcycle lift jack be used to zero in on this little round reinforced point? My jack has the two 1 foot wide slats and a handle to pump the unit up.
  • Kawboy
  • Kawboy's Avatar
1 year 5 months ago
#33350
I wouldn't be lifting the motorcycle off the ground using the engine casing as a point of lift. The reference in the manual for removing the front wheel notes raising the front of the bike by placing a jack under the engine but the amount of pressure on the engine when doing this is minimal. Lifting the entire bike off the ground and using the engine casing as a support point would be a terrible idea.
I would consider fabbing up a jig to sit on your bike lift that lifted the bike using the 2 lower frame tubes that the center stand is attached to. That way you're lifting the bike from the same frame points that the center stand was designed for.
  • scotch
  • scotch's Avatar
1 year 5 months ago
#33356
I made mine and it works beautifully.  Easy to use and solid. My Nickel Plated Balls stay on the forks !
It started it's life originally as a cheap (light-duty) hand cart.  Cut-out what I needed and welded it up as you see it.
Always High - Know Fear !
The following user(s) said Thank You: zed_thirteen, stocktoy
  • jftman
  • Junior Member
  • Junior Member
1 year 4 months ago
#33365
ThankYou for the clarity and a suggestion to use a gig fir the frame tubes.
i really thought more owners would have made an adapter and showed them here.
Time to create page: 0.182 seconds
