Tire Balancing
- dcarver220b
- biltonjim
Re: Tire Balancing
2 months 1 day ago
Years since I did this on my XS1100, but that's a similar method to mine. Do tyres still have a paint dot on the sidewall, which should be aligned nearest the valve when mounting on the rim?
- dcarver220b
Re: Tire Balancing
2 months 22 hours agoSome do - but the Michelin's don't. And this one required more weight than I like to run.. but I'm too lazy to break the bead and move the tire around... so it is what is!Years since I did this on my XS1100, but that's a similar method to mine. Do tyres still have a paint dot on the sidewall, which should be aligned nearest the valve when mounting on the rim?
