Electrical
Stator wires
- fastpapaw
- Junior Member
Stator wires
11 years 1 month ago
I just installed a new stator and would like it to last a while. I've read about soldering the wires. My question is do I just need to solder the connections to the plug or do I need to eliminate the plug completely and solder the wires together.
Thanks!
Thanks!
Mike
'79 KZ1300, '74 Water Buffalo, '82 GS1100, '99 Ducati 996, '95 Goldwing, '13 BMW R1200RT, '13 ZX14R, '06 YZ450F Supermoto
- roadhazard
- Junior Member
Re: Stator wires
Eliminate the connector. That's where the corrosion happens causing voltage drop.
1980 Kz 1300 b2 touring
1980 kz 1300 A2
1980 kz 1300 A2
- Tyler
- Elite Member
Re: Stator wires
Agreed, solder the wires and use shrink wrap over each joint. If properly done the new splice will outlast you.
1981 KZ1300
- fastpapaw
- Junior Member
Re: Stator wires
11 years 1 month agoTyler wrote: Agreed, solder the wires and use shrink wrap over each joint. If properly done the new splice will outlast you.
Especially at my age :woohoo: Thanks!
Mike
Moderators: scotch
Time to create page: 0.167 seconds
