kz1300 banner
Electrical
DYNATEK WIRING CONNECTIONS
  • SIXPIPES
  • SIXPIPES's Avatar Topic Author
  • Senior Member
  • Senior Member
10 years 11 months ago - 10 years 11 months ago
#7968
Hi, while I am waiting for elektronik-sachse to come back off holiday I thought I would take my Dynatek main unit aprt to see if I could find out why it blew. Two days of picking all the encapsulation off and I can see most of the components, I found a couple of dry joints and have re soldered, I also damaged one of the componants while getting all the stuff off so that will have to be re placed. Does any one have one of these units fitted to their bikes as I had to use the wiring from the Dyna for the elektronik-sachse system. I need to know which connections are for the 12v switched live and the 0v into the main unit, I have the connection block with all the pick up wires intact but will need to re connect the coil wires and the live/ov supply.
I will post a picture on here of the stripped unit for interest.
TRIUMPH T120R,BSA A7,BSA A10,BSA SPITFIRE,BSA ROCKET 3 RV,ARIAL SQ 4,S.O.S, RUDGE, BENELLI 750SEI,BENELLI 900SEI, KZ900, SUZUKI GT750, SUZUKI RE5, KAWASAKI H1A, KAWASAKI H2, MOTO GUZZI 850T, NORTON FASTBACK, NORTON INTERSTATE, SUNBEAM S8.
Last edit: 10 years 11 months ago by SIXPIPES.
  • zed_thirteen
  • zed_thirteen's Avatar
Re: DYNATEK WIRING CONNECTIONS
#7972
According to my installation manual the red goes to 12V switched live and the black goes to battery negative. Blue to coil 1-6, white to 2-5 and violet to 3-4. There is also a red wire in this group with 3 spade terminals which connects to the other side of the three coils.
The 2 power connections should already be in a plug housing to connect where the original Kawasaki module connects.
Let me know if you need any more info a I have a dyna2000 system on my bike.
I tried to get the epoxy off mine so I could get in to it but I didn't scratch the surface and was worried about damaging the unit (I think mine packs up when its warm but it could be anything?)
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
  • SIXPIPES
  • Senior Member
  • Senior Member
#7973
My guess would be a dry joint, anyway I learnt a lot taking it apart - I will post a picture tomorrow. I cut the aluminium housing down both sides, the smallest edges are the best to do. I then used a hot air gun and prized the unit from its housing, if you use the hot air gun on the resin type encapsulation that they use, it cuts easily (Stanley knife) and also comes away fairly easy with a small flat screw driver, you will notice a big difference using hot air against trying to do it without.
Do not try this until I post the picture as there are two components that you could easily damage, as long as you know where they are it gives you a fighting chance.
I could do with knowing the exact connections as I had to use some of the wires and one block for my other ignition system.
I have the main block that fits into the Dyna unit but I had to remove the coil wires and the 12v and 0v wires so I do not know which wires go where any more.
  • zed_thirteen
#7983
I think this is probably the best image I managed to capture:
I think if you click on that image it will lead you to the others?
s1195.photobucket.com/user/zed_thirteen/...0DYNA2000%20Ignition
The smaller size wires are the ones from the pick-ups
Hope this helps. If you need more info just ask
1980 CBX1000-A
1990 ZZ-R1100 C1
Last edit: 10 years 11 months ago by zed_thirteen. Reason: add hyperlink
  • SIXPIPES
  • Senior Member
  • Senior Member
#7985
I have no idea how to put pictures on so I had to do a link for the pcb pictures.
Thanks for the pictures of the wiring, tried it on the bench without the coils and the pick ups are switching just fine and working through the unit. I have no LED coming on though so I will replace the capacitor that I damaged and keep my fingers crossed.
mail.aol.com/webmail/getPart?uid=3493848...=2&saveAs=image1.JPG
  • zed_thirteen
#8008
Sorry but those links only work if I log in as you. Can you send them to my PM address please?
1980 CBX1000-A
1990 ZZ-R1100 C1
Moderators: scotch
