kz1300 banner
Electrical
Battery Tender
  • Craig
  • Craig's Avatar Topic Author
Battery Tender
10 years 11 months ago
#8002
Can anyone advise me of a decent battery tender that I can purchase? It must be 220-240v input.
Thanks
  • Kawboy
  • Kawboy's Avatar
Re: Battery Tender
#8006
I see you're in Zimbabwe, and therefore need the 220-240V charger. The other thing that you need to mention when dealing with all us International friends is the frequency of your electrical system. In North America we run on a 60 HZ system, but in the United Kingdom I think they run on a 50 HZ system. Not sure what your system is running at.
In any event, if you want a battery tender, you should be looking for one that charges at around .2 amps and turns itself off when it reaches its desired battery voltage. Therre are lots of decent units over here at around $30.00 that will do the job nicely.
  • Craig
Re: Battery Tender
#8007
Thanks Kawaboy. Yes, we're also 50 HZ
  • BigSix
  • BigSix's Avatar
Re: Battery Tender
#8010
Hi there
I am using this one which is suitable for all kind of batteries and seems to work quite well:
www.louis.de/artikel/procharger-lade-und...003695?list=80115364
(sorry, it's all in German but I hope you can mek it out)
regards
Holger
Z1300 A1/ KZT30AG built 1979
frame KZT30A 004285
engine KZT30A 000288
The following user(s) said Thank You: Craig
Moderators: scotch
Time to create page: 0.204 seconds
