Electrical
Ignition Coil Removal
- Yaegunp
- Elite Member
10 years 9 months ago
Been searching and cannot find any info. In order to remove the ignition coils do I have to remove the top radiator hose aS well? Or am I missing something?
1983 Z1300 A5 plus Sidecar.
- zed_thirteen
Re: Ignition Coil Removal
I don't think so.
First remove the lower two coils by removing the two nuts on the top side of the coil mounting plate (two either side of the upper coil - under the mountain of wiring).
Then remove the two nuts for the upper coil from the underside of the plate.
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
1980 CBX1000-A
1990 ZZ-R1100 C1
The following user(s) said Thank You: Yaegunp
- Lucien-Harpress
Due to the wiring harness, I have to start from the left and work my way right- as you pull each coil, it will open up access to the bolts on the next one. You can pull the wires off once the coils are removed.
- Yaegunp
- Elite Member
Ahh yes that will work I think. Because of the sidecar I was working from the right hand side and from there it meant removing the radiator so you could remove the top hose. There was no way I was getting that right hand side off without doing that, which seemed a little odd to me (pita).
The further I go the more it seems I might have to remove the sidecar;(
- kza13
Damn take the chair off !!!, easy with mine, I dread thinking of you trying to take yours off, might be ok if all the lines have connections, good luck, try and do it with the chair on
Frame No: KZT3OA003911
Engine No: KZT3OAE004153
- Yaegunp
- Elite Member
10 years 9 months agoYaegunp wrote: Ahh yes that will work I think. Because of the sidecar I was working from the right hand side and from there it meant removing the radiator so you could remove the top hose. There was no way I was getting that right hand side off without doing that, which seemed a little odd to me (pita).
A couple of 'bugger this!!' stress moments and 'walk off the job' moments but I got them out eventually. I am learning soooo much and it feels good that I may some day be the master of my own destiny in terms of the Z1300. Hey Pete, I was a poofteenth off taking the sidecar off but after some considered checking of wires I realised they don't all have connections so I persevered with it still connected. Though I might have to go and see my osteopath sooner rather than later :pinch:.
Making the sidecar easier to remove will be another project in itself, I have done preliminary investigations and to do it properly will take some time and effort. I am reluctant to go too deep into the project so as to avoid drowning in information and loose parts all over the place
Moderators: scotch
Time to create page: 0.203 seconds
