Electrical
Voltage regulator size
- mmoody66
- Junior Member
10 years 8 months ago
Hi I have 2 regulators come in the box of bits with the bike
One is larger size than the other but both have the same wire connections
The smaller one has a sticker from a supplier with KZ1300 79-81
The larger one wiring all been tampered with with scotch locks etc
My bike is 81 A 3 with the side engine pick ups
Can I use the smaller one ?????
- Mark
- Elite Member
Re: Voltage regulator size
If you can mount it to the frame you should have no problem, Pick-ups and Ignitor can't be interchanged. Honda tend to do a universal Reg/Rec so foresee no issues using the smaller one. Maybe one of the tech boffins will say different but I doubt it
17 years a Z13 owner at present 3 x A1's and an A4
- Kawboy
I seem to recall a conversation about this once before regarding the 2 regulators/rectifiers related to the 82 model with the 2 alternators. I thought we figured out that one of the units was a master and one was a slave??
Moderators: scotch
Time to create page: 0.611 seconds
