kz1300 banner
Electrical
Main switch under seat
  • mmoody66
  • mmoody66's Avatar Topic Author
  • Junior Member
  • Junior Member
10 years 8 months ago
#9639
Hi just getting the big girl together
Normally run a 900r
The switch under the seat I don't seem to have a key for
I have the ignition key that fits the normal way in the traditional position
but it does not work in the main switch under seat / side casing
Is this normal to have 2 X different keys ?
Any easy solution to my woes
Thanks
i202.photobucket.com/albums/aa310/GPZ900...age_zpsemrnx7sa.jpeg
  • AERIAL0
  • AERIAL0's Avatar
  • New Member
  • New Member
Re: Main switch under seat
#9640
One key should fit all. Has seat unit lock/switch been changed at some time?
  • mmoody66
  • Junior Member
  • Junior Member
#9641
Not sure bike been stripped since late 80s in boxes 1 owner from new
Or though I was told bike was running when stripped
I received it in boxes so have no idea, maybe lock broken when I first put the key the lock turned clock ways but then won't turn at all
  • AERIAL0
  • AERIAL0's Avatar
  • New Member
  • New Member
#9643
Gather youve sprayed with WD40? Had problems with locks b4 and ended up imersing in diesel for a few days and worked.
if that fails. They do come up on ebay.
  • Kawboy
  • Kawboy's Avatar
#9646
AERIAL0 wrote: Gather youve sprayed with WD40? Had problems with locks b4 and ended up imersing in diesel for a few days and worked.
Agreed. Give it a good soak with penetrating oil. Knowing the way tumbler pins work in a lock, it could just be a stuck pin in the tumbler. Let it soak and once in a while pull the key in and out to move the pins around. It should clear itself if it's tumbled to the same key as the ignition.
  • mmoody66
  • Junior Member
  • Junior Member
#9652
Thanks did spray it with Wd 40
But may needs better soaking
Will give it good dosing
Let you know how I get on
Moderators: scotch
