- Thank you received: 9
Electrical
Main fuse blowing
- rdbhere2
- Elite Member
10 years 4 months ago #10918
by rdbhere2
Main fuse blowing was created by rdbhere2
I've ridin my bike a few times when the temperature was around 35 degrees and the main fuse blew 3 times when down shifting to stop at a red light and stop signs. Would the cold and or down shifting have something to do with the 30 amp fuse blowing?
- zed_thirteen
- Thank you received: 147
10 years 4 months ago #10920
by zed_thirteen
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
Replied by zed_thirteen on topic Main fuse blowing
If you were also braking then I would check the pair of wires from the front brake switch under the fuel tank. I think the pair of wires pass through two bullet connectors. I've had an issue myself in the garage where one was shorting battery to ground when it had been left exposed.
1980 CBX1000-A
1990 ZZ-R1100 C1
- rdbhere2
- Elite Member
10 years 4 months ago #10935
by rdbhere2
Replied by rdbhere2 on topic Main fuse blowing
God idea. I'll have to check those connectors. Im almost certain I I was just down shifting and pulling in the clutch when the main fuse blew and cut power to the bike. That's what was so weird about the who thing.
- zed_thirteen
10 years 4 months ago #10942
by zed_thirteen
1980 CBX1000-A
1990 ZZ-R1100 C1
Maybe check the clutch lockout switch wiring from the left hand lever. Maybe someone has modified those two wires so that you don't have to pull the clutch to start the bike?
1980 CBX1000-A
1990 ZZ-R1100 C1
- rdbhere2
- Elite Member
10 years 4 months ago #10943
by rdbhere2
I soldered the two wires together at the handlebar clutch switch and insulated them. I removed the signal lights fuse and once again the main fuse blew while on a test ride in cold weather while down shifting. I'll have to go through the connectionsundrr the tank again.
- 6cylinder
- Thank you received: 13
10 years 4 months ago #10946
by 6cylinder
millers auto electric
Replied by 6cylinder on topic Main fuse blowing
I have a couple of questions about your bike? what year and model? Is the thirty amp fuse the only fuse that blows? have you tried not down shifting? does it still blow fuse? and is the battery strapped down in place?
after searching the wiring diagrams brake light switches are not in that circuit.
thanks I will keep looking to see what I can find...
Moderators: scotch
Time to create page: 0.113 seconds
