kz1300 banner
Electrical
Main fuse blowing
  • rdbhere2
  • rdbhere2's Avatar Topic Author
  • Elite Member
  • Elite Member
Main fuse blowing
10 years 4 months ago
#10918
I've ridin my bike a few times when the temperature was around 35 degrees and the main fuse blew 3 times when down shifting to stop at a red light and stop signs. Would the cold and or down shifting have something to do with the 30 amp fuse blowing?
  • zed_thirteen
  • zed_thirteen's Avatar
Re: Main fuse blowing
#10920
If you were also braking then I would check the pair of wires from the front brake switch under the fuel tank. I think the pair of wires pass through two bullet connectors. I've had an issue myself in the garage where one was shorting battery to ground when it had been left exposed.
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
  • rdbhere2
  • Elite Member
  • Elite Member
#10935
God idea. I'll have to check those connectors. Im almost certain I I was just down shifting and pulling in the clutch when the main fuse blew and cut power to the bike. That's what was so weird about the who thing.
  • zed_thirteen
#10942
Maybe check the clutch lockout switch wiring from the left hand lever. Maybe someone has modified those two wires so that you don't have to pull the clutch to start the bike?
1980 CBX1000-A
1990 ZZ-R1100 C1
  • rdbhere2
  • Elite Member
  • Elite Member
#10943
I soldered the two wires together at the handlebar clutch switch and insulated them. I removed the signal lights fuse and once again the main fuse blew while on a test ride in cold weather while down shifting. I'll have to go through the connectionsundrr the tank again.
  • 6cylinder
  • 6cylinder's Avatar
  • Premium Member
  • Premium Member
#10946
I have a couple of questions about your bike? what year and model? Is the thirty amp fuse the only fuse that blows? have you tried not down shifting? does it still blow fuse? and is the battery strapped down in place?
after searching the wiring diagrams brake light switches are not in that circuit.
thanks I will keep looking to see what I can find...
millers auto electric
Moderators: scotch
Time to create page: 0.176 seconds
