kz1300 banner
Electrical
Instrument cluster distance sensor
  • Don_Karlos
  • Topic Author
  • Junior Member
  • Junior Member
10 years 2 months ago #11846 by Don_Karlos
Instrument cluster distance sensor was created by Don_Karlos
Hi,
I'm in the last phase of my rebuild. Now I'm working on the electrical system. I removed the instrument cluster and found one wire disconnected from the back of the tachometer. In the shop manual the part to which it was soldered is called "distance sensor". What is this and what is it for? Since the part itself is glued into the backplate of the instrument cluster there is no way to replace it. If I can't repair it, what function will be missing?
Thanks
Karl
  • zed_thirteen
10 years 2 months ago #11847 by zed_thirteen
Replied by zed_thirteen on topic Instrument cluster distance sensor
I think this was to do with the indicator self cancelling circuit that turns the indicator off after a certain distance.
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
  • LareNurminen
10 years 2 months ago #11850 by LareNurminen
Replied by LareNurminen on topic Instrument cluster distance sensor
The sensor gives pulses to the self-cancelling unit located below the battery tray. Once the bike has traveled far enough, the unit actuates the solenoid located inside the left side switch cluster, returning the indicator slide to center position.
The following user(s) said Thank You: Don_Karlos
  • Don_Karlos
  • Topic Author
  • Junior Member
  • Junior Member
10 years 2 months ago #11854 by Don_Karlos
Replied by Don_Karlos on topic Instrument cluster distance sensor
Ok,
I understand. I'll try to solder the loose wire back on.
Thanks
Karl
  • Don_Karlos
  • Topic Author
  • Junior Member
  • Junior Member
10 years 1 month ago #11946 by Don_Karlos
Didn't work out:-(
But since I found other Problems I'll get rid off the self cancling stuff anyway. See my other post....
Thanks for your advice and help!
Karl
  • zed_thirteen
10 years 1 month ago #11948 by zed_thirteen
I've had about 3 of the self cancelling modules fail on me. I've given up on them now.
There was a circuit design somewhere for a DIY version
1980 CBX1000-A
1990 ZZ-R1100 C1
Moderators: scotch
Time to create page: 0.108 seconds
