kz1300 banner
Electrical
Voyager fan switch 27010-1026 used in a Kz1300 B2
  • Phil
  • Phil's Avatar
Re: Voyager fan switch 27010-1026 used in a Kz1300 B2
9 years 11 months ago
#13619
That Voyager temp. fan switch you're referring to brings the fan on 5 degs. (?) earlier than the carb model ones; if you're worrying about the fan staying on excessively when the ignition is turned off -don't- because it doesn't ;) I have the same switch on mine (they were fitted to my later ZG1300 DFI model also) & it only runs for about 10 seconds once, sometimes twice after shutdown, same as the carb models if I'm not mistaken :)
Moderators: scotch
Time to create page: 0.156 seconds
