kz1300 banner
Electrical
Voyager fan switch 27010-1026 used in a Kz1300 B2
  • rdbhere2
  • rdbhere2's Avatar Topic Author
  • Elite Member
  • Elite Member
9 years 11 months ago
#13613
Has anyone used a manual fan switch to stop the cooling fan from staying on when the bike is not running? Or wired the fan switch to the ignition switch so the fan turns off when the ignition switch is off?
  • Phil
  • Phil's Avatar
Re: Voyager fan switch 27010-1026 used in a Kz1300 B2
#13614
With respect, is that wise? The reason the fan still runs when the ignition is off is to get rid of residual heat. You're at risk of cooking the engine if you bypass that feature IMO :)
  • rdbhere2
  • Elite Member
  • Elite Member
9 years 11 months ago - 9 years 11 months ago
#13615
The temperature is always at the midway mark on the temp gauge when the bike comes to a stop. No harm done if the fan is turned off at that point.
Last edit: 9 years 11 months ago by rdbhere2.
  • 6cylinder
  • 6cylinder's Avatar
  • Premium Member
  • Premium Member
#13616
Phil is right, its good advice..
millers auto electric
  • Mark
  • Mark's Avatar
  • Elite Member
  • Elite Member
#13617
Not a good idea, once stopped it will get hotter as not able to dissipate the heat it cuts in on shutdown for a reason. Don't create yourself a problem
17 years a Z13 owner at present 3 x A1's and an A4
  • rdbhere2
  • Elite Member
  • Elite Member
#13618
I know I'm not the only one to put in a low temperature fan switch. I'm just trying to find out what those persons did to stop the fan from running once the engine has cooled below the normal temperature mark. I've seen a thread about using a low temp switch, I just can't find it in the forums. Thanks for the advice from you guys.
Moderators: scotch
Time to create page: 0.154 seconds
