Electrical
Fuel sender leaking
- kiwirider
Fuel sender leaking
9 years 7 months ago
Hi can anyone please tell me if anyone is making aftermarket fuel senders mine started leaking from the signal wire and has been butchered. I missed out on a new one from Zed parts by a day they are sending me a second hand unit and have been very helpful.I might get to ride it one day lol.
2018 Harley cvo ultra 1982 cbx1000 1980 gsx1100 2012 gtr1400 cx500 turbo 1977 suzuki gt750
- Kawboy
Re: Fuel sender leaking
How was it butchered? I'd be surprised if it couldn't be repaired. A few pics would be nice to help us understand what you're dealing with.
- kiwirider
thanks for the reply they have re soldered the sender wire and then covered it in rt v i peeled it off and the plastic washer is loose have you repaired these before and how because the wire on the inside is very small .The tank is very rusty inside i am going to clean and seal it .I have a z1r that had the same fault i got a new one from web bike.Ill post some pictures soon you have some great ideas and i agree with you when you said don't trust anyone who has worked on your bike because everything that i was told had been done is rubbish.what cam chain tension er modification do you recommend you have been doing great work and posting great threads i dont know were you find the time thanks again Graham
- kza13
one of the guys on here took his unit to an instrument repair place, people who do speedos and gauges and the like, they did a good job, fixed it right up, i've soldered the fine wire in mine very carefully, but haven't had the plastic washer problem. There is plenty of threads on here about the replacement tensioner you can buy, bolts straight on except you have to cut 10mm off the spring inside the new tensioner, hope it all turns out ok, cheers Pete.
Frame No: KZT3OA003911
Engine No: KZT3OAE004153
The following user(s) said Thank You: kiwirider
- kiwirider
thanks Pete you are in a similar time zone im off to the hardware store to get some metal rescue to clean rust out now cheers Graham Ill let you know hoe i get on with sender
- kiwirider
Re: photo sender unit
Moderators: scotch
Time to create page: 0.167 seconds
