kz1300 banner
Electrical
missing spark
  • paulb
  • paulb's Avatar Topic Author
  • Elite Member
  • Elite Member
missing spark
9 years 2 months ago
#15509
Hi Guys
i am in the process of trying to get a z1300 up and running, i had it started and running fairly well a couple of weeks ago but when i have tried to start it recently i seem to have lost the spark, i have a spare cdi and tried that but still no joy even using easy start dosnt seem to get any sort of response
any ideas
thanks
Paul
  • McZed
  • McZed's Avatar
  • Elite Member
  • Elite Member
Re: missing spark
#15511
If you haven't already done so, check the coils. The originals are prone to cracking.
Z1300 UK
  • kza13
  • kza13's Avatar
Re: missing spark
#15512
Check switch under seat, has to be horizontal, kill switch short, clutch safety switch, main ignition on and tell tales working?, fuses, power to coils ??, usual stuff
Frame No: KZT3OA003911
Engine No: KZT3OAE004153
  • paulb
  • Elite Member
  • Elite Member
Re: missing spark
#15514
Hi
i have power so assume its not to do with the kill switch or the power switch beneath the side panel, also i have no spark anywhere so if it were a coil i assume it would fire on the other cylinders
  • stocktoy
  • stocktoy's Avatar
Re: missing spark
#15515
if you have a 79 it maybe the pickups on the timing advancer they were a weak point on the 79's I understand.
Are you getting a pulse signal when you crank it over?
Moderators: scotch
Time to create page: 0.200 seconds
