kz1300 banner
Electrical
Spark Plug Heat Rating ???
  • BigSix
  • BigSix's Avatar
Re: Spark Plug Heat Rating ???
9 years 2 weeks ago
#16628
Initially the question about the "R" has been raised. According to what I learnt this indicates the spark plug will not interfere with radio receivers. Of course that is not needed if your spark plug connector is already protected.
regards
Holger
Z1300 A1/ KZT30AG built 1979
frame KZT30A 004285
engine KZT30A 000288
  • Ledkz1300
  • Ledkz1300's Avatar
9 years 2 days ago
#16688
You only need 3 dials to sync the carbs. Each carb "pair" shares their sync adjustment. You can use either of the two intake paths to attach the hoses to sync the carbs.
Moderators: scotch
