Electrical
Question about timing on A1
- scotch
Re: Question about timing on A1
9 years 1 month ago
I'm with Kawboy. I wouldn't start filing-out holes until you've tried re-indexing one tooth, first. However my question would be: If the initial timing is on the mark and the full advance timing is working as you indicate, why would you "Elongate" the pick-up plate holes ? Just curious.
Always High - Know Fear !
- scotch
9 years 1 month ago
KZA13 wrote: <" not sure if it's fuel supply or timing or shims, sometimes she doesn't seem to be running on all 6, idles good, revs good, sometimes a bit of a pop either in the exhaust or back thru carb, not sure which cylinder, getting lazy and haven't really gotten into it yet .....">
Two contradictions which makes trying to do an internet diagnose impossible ! Fuel? Timing? (apparently OK). Valve clearances? Confused as to how it can seem to not be running on all six but idles and revs good. You've got to get the simple stuff sorted out first. MANUAL ! Fuel flow good - Move on. Ignition timing - OK - move on. Valve clearances - check and shim as required - move on. Coils, leads and plugs Good(?) - move on. At this point, filing out timing plate holes is redundant. The only thing left and the most likely is the carbs. "Popping" is generally a positive indicator of a blocked/partially blocked idle jet(s). With the engine warmed up pull one plug-lead at a time. Odds are you'll find your problem cyl. Get a Cleaning Tool and solve the "Popping" issues.
- kza13
9 years 1 month ago
Got a cleaning tool, that's the carbs that are on there now, all nice and clean and shiney.... But I digress .... I will admit that I am an old idiot, and I really should invest in a new pair of glasses, guess who timed it to the wrong mark ???, PETE DID !!!!!!!!! , it really helps to do it in the afternoon with the sun shining thru the door and onto the bike timing area, so some d***head can see the big giant "F" beside the right mark, oh well at least i'm man enough to admit my mistake and not bullshit everybody with some made up story about how it was something else, wonder if they make glasses out of really big magnifying glasses ???, it'd probably help this old blind bugger
, cheers all from a humble Pete. (silly old fart)
Frame No: KZT3OA003911
Engine No: KZT3OAE004153
- kiwirider
9 years 1 month ago
Good result well done Pete
2018 Harley cvo ultra 1982 cbx1000 1980 gsx1100 2012 gtr1400 cx500 turbo 1977 suzuki gt750
- Kawboy
9 years 1 month agoJust change the "Q" on your licence plate to an "O" and all will be forgiven. I do thank you for the opportunity to scratch my head a few times :whistle:kza13 wrote: Got a cleaning tool, that's the carbs that are on there now, all nice and clean and shiney.... But I digress .... I will admit that I am an old idiot, and I really should invest in a new pair of glasses, guess who timed it to the wrong mark ???, PETE DID !!!!!!!!! , it really helps to do it in the afternoon with the sun shining thru the door and onto the bike timing area, so some d***head can see the big giant "F" beside the right mark, oh well at least i'm man enough to admit my mistake and not bullshit everybody with some made up story about how it was something else, wonder if they make glasses out of really big magnifying glasses ???, it'd probably help this old blind bugger![]()
So the question is "Did the pickup coil plate realign itself back into the center of the slots?"
- scotch
9 years 1 month ago
A simple mistake discovered and corrected can solve a lot of issues! A great learning point for all. Good news !
Moderators: scotch
Time to create page: 0.205 seconds
