kz1300 banner
Electrical
pick up assembly
  • paulb
  • paulb's Avatar Topic Author
  • Elite Member
  • Elite Member
pick up assembly
9 years 1 month ago
#16302
Hi
i have an oil leak which i believe is coming from where the pick up assembly goes into the block, i had the o ring changed but it is still leaking i am now going to try and check it myself, my question is can i just simply pull it out of the block change the o ring and push it back and should i use any sealant on the o ring
many thanks
Paul
  • Kawboy
  • Kawboy's Avatar
Re: pick up assembly
9 years 1 month ago
#16303
Good rule of thumb for installation of all o-rings and lip seals is to apply a smear of the fluid the seal or o-ring is sealing on the sealing surface. A lot of seals and o-rings are composed of material to work with the fluid it's sealing and applying some kind of lubricant that's not similar to the fluid being sealed, may ruin the seal.
If installing a lip seal and the casing of the seal is metallic, you can apply a smear of silicone based engine assembly sealant to the lip seal outer case and then install the seal. If you put any sealant on the bore that the seal will be installed into, as the seal is installed, it will push that sealant ahead of it and cause a build up of sealant inside of the engine that can break off and end up in the engine sump. Hence a lot of members pulling the sump and finding silicone jammed up in the oil pick up screen. That is completely accountable from poor maintenance activities such as what I just described.
  • paulb
  • Elite Member
  • Elite Member
9 years 1 month ago
#16305
Thanks Kawboy as for removing it can it just be pulled out once the 2 retaining bolts are undone
  • Kawboy
  • Kawboy's Avatar
9 years 1 month ago
#16307
paulb wrote: Thanks Kawboy as for removing it can it just be pulled out once the 2 retaining bolts are undone
Yes Sir.
  • scotch
  • scotch's Avatar
9 years 1 month ago
#16310
Keep us in the loop with this one paulb. Interested to hear what you find.
Always High - Know Fear !
Moderators: scotch
Time to create page: 0.167 seconds
