Electrical
ZN1300 - What the heck is this black fuse box?
- Bucko
8 years 11 months ago
MY ZN has a 3 inch Bakelite 'GE" box spliced into the ground cable. The box holds a 'bus' style fuse except the fuse had been replaced with a small piece of pipe. I'm assuming this is not original. The only reason I can guess that's it there is as a 'poor man's' quick battery disconnect - if so not sure why it's not spliced in to the positive side of the battery - maybe because the ground cable is more accessible?. In in case, I plan to get rid of it.
Does any of this make sense?
- Bucko
Re: ZN1300 - What the heck is this black fuse box?
8 years 10 months ago - 8 years 10 months ago
Well, I was wrong, the 'fuse box' was on the positive side of the battery. In any case, I yanked it out. Didn't look like an OEM part to me. My guess is somewhere out there, there's a Harley-Ferguson with a critical part missing:
Last edit: 8 years 10 months ago by Bucko.
- Kawboy
That's a quick fix when there's a bad diode in the voltage rectifier. A bad diode will leak voltage from the negative to the positive side of the battery and cause the battery to go dead. Installing a dicconnect opens the circuit. so the battery doesn't die when the bike is shut off.. So add to your check list to check the rectifier..
The following user(s) said Thank You: Bucko
- Bucko
Good advice. Thanks Kawboy.
Moderators: scotch
Time to create page: 0.174 seconds
