Electrical
M-Unit Blue- Motogadget
- McBoney
Re: M-Unit Blue- Motogadget
6 years 3 months ago - 6 years 3 months ago
Thank you!
I am on holiday at the moment, so have not seen this until just now.
Here is a site I found particularly useful: bikebrewers.com/motogadget-m-unit-wiring/ and this video, although a little long, is very clear on how the wiring works..
I will be back in UK on 17th and then plan a week to put my bike back together. Then after that I'll start the wiring. I have what I want configuration-wise in my head, I may just write that down first, then maybe design the circuits on paper, one by one. Then combine all of them into a plan for a wiring diagram. My bike is ground-up and minimal functions, so should be as simple as I can keep it. As much of it within the frame rails as possible.
Once the complete diagram has been reviewed by whomever feels competent, I can then transfer that to buying stuff and putting it onto the bike.
It will be a while before I get to this point but I'm glad I found the thread!
Cheers
Paul
Cheers
Paul
Six-Pot-Cafe in the making...
Last edit: 6 years 3 months ago by McBoney.
- tackelhappy
Sounds good. That video must be fairly old ( not that it really matters ) as it is the first generation- but they all work essentially the same.
One thing tho. If you haven't made any provision now of where you will mount for instance the necessary hardware - starter solenoid , coils, ignitor and you have removed various brackets, or haven't, and the bike gets re-assembled, the frame is painted , then the mounting options are restricted to their original place. Or as in my case , having to repaint after installing the new Blue unit in a different place than I original thought- moving the battery etc.
If I was doing this all over a gain now, I would have reassembled the bike completely in an unpainted condition to get everything set out properly, but then have to dis assemble , paint , put back together. Welding on a new bracket can't be done with any of the electronics I have on my bike without removing them first.
There again, you may have this figured already.
OKANAGAN FALLS. BC ,Canada
Last edit: 6 years 3 months ago by tackelhappy.
- McBoney
Thanks.
I am planning to put all the electronics (battery, M-Blue unit, solenoid, regulator and, if it fits, the igniter) in a made-to-measure waterproof box right behind the engine and before the swing arm. The box itself will be bolted (and grounded) to the frame using two existing brackets that I am not sure what they are used for, but are situated on the cross bar underneath the battery tray brackets. I may also use the battery tray brackets to mount something, if it doesn't fit in the box.
Paul
Paul
Moderators: scotch
Time to create page: 0.173 seconds
