Electrical
accel vs dyna coils...
- met1212
- Senior Member
7 years 11 months ago
anyone out there with experience in dealing with either accel or dyna coils...?
and verdict as whats the better of the two options...?
- biltonjim
Re: accel vs dyna coils...
I'd be interested to hear, too. My KZ1300 A4 , which I bought several years ago as a restoration project, has Accel coils. After all the recent debate on this forum regarding replacement coils, and the importance of having the correct primary resistance, it has got me wondering what the resistance of the Accel coils is.
- RChaloner
- Elite Member
Not familiar with either type Jim, but one bit of advice (based on my own testing of the infamous AW82-TR jobbies) is to never assume the resistance from what's published, but measure the buggers yourself with an accurate meter!
Mine were all getting on for 10% low and that's enough to put the all-up resistance into an uncomfortable area.
Richard.
Richard.
1979 KZ1300 A1
1999 K1200LT - now sold, I like them however was nearly as big as my X5 but no faster.
- met1212
- Senior Member
7 years 11 months ago - 7 years 11 months ago
i tried the aw82-tr option.....and it was all a waste of time and money.
it ran on 3 cylinders before the aw82-tr option and ran on all 6 for a day after the big op.....now i 'm back to square 1 with only 3 cylinders working.... so i guess the next thing, (short of taking the pile of junk and over the next 100 ft cliff) is replacing the aw82-tr coils with either accel or dyna coils.......
Last edit: 7 years 11 months ago by met1212.
- RChaloner
- Elite Member
Yikes that's frustrating.
You don't think it might be igniter (or whatever it's called) or loom related do you?
Especially if your lovely AW82 coils all buzz through OK, although loss of 3 cylinders isn't consistent with the paired coil supply and (I assume) 3 x igniter outputs for the 3 coils.
Any chance you may be running on 2 or 4 cylinders?
I guess the easy tests are either pulling the plug leads individually or feeling the header tubes shortly after start.
(apologies if your feedback is already based on all these!)
The cliff option is an interesting one, those 41mm forks should hold up well, but my concern is due to the weight it'll end up half embedded into the ground below and every time you pass that way you'll see that numberplate grinning up at you...
1979 KZ1300 A1
The following user(s) said Thank You: met1212
- Kawboy
7 years 11 months ago - 7 years 11 months agoNote that 1 coil feeds 2 cylinders are you sure you are dead on three cylinders? And if so, which 3 are dead? This wiĺl help determine the problem.met1212 wrote: i tried the aw82-tr option.....and it was all a waste of time and money.
When you changed the coils , did you happen to change the spark plugs too?
Last edit: 7 years 11 months ago by Kawboy.
Moderators: scotch
Time to create page: 0.166 seconds
