Another Iridium spark plug question
- Gunhog63
- New Member
Please forgive my ignorance but is it ok to use iridium plugs which I assume have a built in resistance with NGK caps which also have a built in resistance. I have a set of BPR 6EIX. I have new coils that I got off www.z1300.de which tell you not to use the ballast resistor and includes a by pass mini loom to fit in its place. I hope this makes sense.
Any advice greatly appreciated
1980 KZ1300A2
My only fear is that when I die my wife sells my bike for what I have told her I spent on it.
- scotch
- Thank you received: 931
Always High - Know Fear !
- Bucko
- Thank you received: 165
Gunhog63 wrote: Hi all
The ballast resistors are part of the coil input circuit, not the output circuit where the spark plugs are connected.
- Gunhog63
- New Member
Is that a yes or a no?
Cheers
1980 KZ1300A2
- Kawboy
- Thank you received: 1198
KB
- Gunhog63
- New Member
Thanks for that. My restoration project has been an 18 month journey of discovery.
Nearing completion now
Cheers
1980 KZ1300A2
