kz1300 banner
Electrical
Fan override
  • Badger
  • Topic Author
6 years 8 months ago #25093 by Badger
Fan override was created by Badger
Can I interrupt the fan switch to manually activate the fan at slow speeds?
6 years 8 months ago #25100 by scotch
Replied by scotch on topic Fan override
The fans' thermostatic switch simply grounds the circuit (when the coolant temp. is high enough to activate this switch (sensor), completing the circuit. To add a manual activation switch simply connect another wire to the fan sensor , run it through a on/off switch and ground the other side of the auxiliary switch.
Always High - Know Fear !
  • Badger
  • Topic Author
6 years 8 months ago #25101 by Badger
Replied by Badger on topic Fan override
Thank you scotch. I love this forum!!
Moderators: scotch
Time to create page: 0.101 seconds
