Electrical
coils and HT leads
- CWB
- Senior Member
coils and HT leads
6 years 3 months ago
Ignition coils and HT lead order. I see Page 49 in the manual as advised and for example the manual states the centre coil (which is the top coil) has HT leads to 1 and 6 plugs. However I need clarification if it matters which HT lead from the coil goes to plug or 6 or plug 1. ie the left lead or the right lead.
Thanks
Bill
Thanks
Bill
- biltonjim
Re: coils and HT leads
don’t think it matters - the coil fires both 1 and 6 plugs simultaneously- but of course only one of those cylinders is on the power stroke at once, so the the other is a ‘wasted’ spark. I hope that makes sense!
- Phil
As biltonjim said, it matters not, per cylinder there's a spark every other revolution of the engine as it's a wasted spark ignition system
The following user(s) said Thank You: CWB
- Bucko
6 years 3 months ago - 6 years 3 months ago
As other's have suggested, it doesn't matter - but if you have original lenght wires, you may find they won't reach the plugs if you take them to the wrong side (prettys sure the left wire goes to 1 and the right goes to 6.
Further, and you can add this to the list of anal things to be concerned about....
Since, for any given pair of plugs on the same coil, one plug fires from the center electrode and it's pair fires to the center electrode, when I pull my plugs, I always swap within pairs when putting them back in. Probably doesn't really do anything, but some folks are sold or iridium plugs and if the iridium really does do anything (only the center electrode is iridium), then swapping within pairs occasionally may make them last longer/perform better).
Last edit: 6 years 3 months ago by Bucko.
- Kawboy
6 years 3 months agoBucko wrote: As other's have suggested, it doesn't matter - but if you have original lenght wires, you may find they won't reach the plugs if you take them to the wrong side (prettys sure the left wire goes to 1 and the right goes to 6.
Just for you Bucko- NGK makes an IFR6B plug that is iridium center electrode and a platinum ground electrode. More even wear for those "wasted Spark" engines. No more need to swap plugs around. I've also seen double iridium plugs but the identifier number escapes me at the moment.
The following user(s) said Thank You: Bucko, CWB
- Bucko
Thanks Kawboy. TIL - good to know.
Moderators: scotch
Time to create page: 0.184 seconds
