Electrical
Sub Alternator Connector Location.
- McBoney
Re: Sub Alternator Connector Location.
5 years 8 months agoKawboy wrote: Sometimes a pic is worth a thousand words. This pic of an aux (left side stator) came from an ad on EBay and judging by the length of the lead coming from the stator, I'd say the stator plugs directly in to the aux regulator/rectifier.
Hope this helps.
KB
I can confirm that, when rebuilding mine the yellow three wires went straight into the regulator. This was the instruction on my new Shindengen.
Paul
Six-Pot-Cafe in the making...
- Bucko
The wiring diagram shows the sub R/R's connector setup is different. The sub R/R has a connector on the body of the RR itself unlike the main R/R which has two pigtails (I've verified the sub R/R connector is clean and in good shape. From the connector at the sub R/R body there's a pigtail that goes to the stator connector (which I assume is a 4 pin connector similar to the main stator connector) - that's the one I can't locate.
- Bar
- Elite Member
Good day Bucko,
I also have the ZN1300, my electrical system is completely redone
as much as I remember this connector is under the left side cover by the starter relay , maybe need to remove the seat but at the same area.
I can check later when I get home as I still have the original harness and will confirm
Eran
Eran
1984 Kawasaki Voyager
2002 Honda CBR954
2002 Honda CBR954
- Bar
- Elite Member
5 years 8 months ago - 5 years 8 months ago
OK, Just confirmed
the main stator connector is under the right side cover by the fuel pump
the sub stator connector is under the left side cover by the starter relay, there is a small bracket with two relays and the starter relay
I believe is on the same bracket or behind it
Eran
Eran
2002 Honda CBR954
2002 Honda CBR954
Last edit: 5 years 8 months ago by Bar.
The following user(s) said Thank You: Bucko
- Bar
- Elite Member
5 years 8 months agoBucko wrote: The wiring diagram shows the sub R/R's connector setup is different. The sub R/R has a connector on the body of the RR itself unlike the main R/R which has two pigtails (I've verified the sub R/R connector is clean and in good shape. From the connector at the sub R/R body there's a pigtail that goes to the stator connector (which I assume is a 4 pin connector similar to the main stator connector) - that's the one I can't locate.
3 pin connector for the sub stator and not 4 like the main
2002 Honda CBR954
2002 Honda CBR954
- Bucko
Thanks Bar. Will check that out. It's the 3 pin connector that is part of the reason why I couldn't find it. Is the "small bracket with two relays " the bracket that is screwed into the frame and also holds the sub R/R?
Moderators: scotch
Time to create page: 0.166 seconds
