- Thank you received: 21
Electrical
Faulty pick up coils?
- englishcw
- Senior Member
3 years 8 months ago #30738
by englishcw
Replied by englishcw on topic Faulty pick up coils?
I think that may be Me . still waitng Addy .
- PaulD
- Thank you received: 29
3 years 8 months ago #30741
by PaulD
Replied by PaulD on topic Faulty pick up coils?
- PaulD
3 years 8 months ago #30745
by PaulD
Many thanks to Clive who kindly posted me known working igniter unit. I’ve just put it on the bike and tried it but unfortunately it made no difference at all. The bike took ages to catch and run then ran like a bag of sh1t
he mentioned his bike was showing similar symptoms which turned out to be the cam timing which had jumped a tooth. I did check this earlier on when the problems first started but it looked ok to me? It also ran perfectly for a while which sort of rules that out but I’m clutching at straws now so I’ll check again. Any hints and suggestions welcome before I set fire to the bloody thing.
- Kawboy
- Thank you received: 1198
3 years 8 months ago #30746
by Kawboy
Replied by Kawboy on topic Faulty pick up coils?
i've been waiting to hear the result of cranking over with the sparkplugs in and the battery voltage. if that is over 9 volts during cranking, I was going to suggest that the cam timing would be next on my list.
The fact that it won't fire on choke with the choke mod done and the ignition timing is checked and ok along with the spark being confirmed, it leads me to believe that the cam timing is off and that is causing low intake vacuum.
I've seen motors running fine and get shut off and the next day won't run and what happens is if the cam chain is loose enough, turning off the engine causes a drag force on the cam chain and the camshafts are still turning forward and the slack in the cam chain instead of being at or near the tensioner roller is now at the the exhaust cam and that's when the chain jumps a tooth, sometimes on just the exhaust cam and sometimes on both cams. Hyvo chains are a little more susceptible to this happening than roller chains.
So, yes check your valve timing.
The following user(s) said Thank You: PaulD
- dcarver220b
- Thank you received: 294
3 years 8 months ago #30747
by dcarver220b
Replied by dcarver220b on topic Faulty pick up coils?
Frustrating.. but keep after it!
- PaulD
3 years 8 months ago #30750
by PaulD
The cranking voltage with plugs in and HT leads connected is just over 10 volts so I’ll check the cam timing over the weekend and report back.
Moderators: scotch
Time to create page: 0.131 seconds
