- Thank you received: 147
Electrical
1979 Kz1300 A1 Replacement starter
- zed_thirteen
3 years 8 months ago #30782
by zed_thirteen
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
Replied by zed_thirteen on topic 1979 Kz1300 A1 Replacement starter
1980 CBX1000-A
1990 ZZ-R1100 C1
The following user(s) said Thank You: giorgi3
- giorgi3
- Senior Member
- Thank you received: 10
3 years 8 months ago #30783
by giorgi3
Replied by giorgi3 on topic 1979 Kz1300 A1 Replacement starter
Dang, That's the way it should start!!
Did you find that the Ricks Starter was a bit shorter than the original? Also did the Ricks Starter seem very tight on the gear when in place? Either of these a concern for you?
Sadly, I shipped my Ricks Starter back already without actually trying it. I guess I will try to rebuild the original, and if that doesn't work I'll order one again.
- zed_thirteen
3 years 8 months ago #30784
by zed_thirteen
1980 CBX1000-A
1990 ZZ-R1100 C1
I didn't notice it was any shorter or tight on the gear
1980 CBX1000-A
1990 ZZ-R1100 C1
- giorgi3
- Senior Member
3 years 8 months ago #30787
by giorgi3
Hmm... I'm pretty sure I got the right one from RIcks, but it was definitely a little shorter (the old one was flush against the end of 'clutch' gear, the Ricks starter was at least 1/8 inch short of reaching the end. ugg.
Anyway, thanks!
Anyway, thanks!
- dcarver220b
- Thank you received: 294
3 years 8 months ago #30798
by dcarver220b
Replied by dcarver220b on topic 1979 Kz1300 A1 Replacement starter
Ricks has always been good to me when calling with questions. Seems to me that all parts can be refurbished by the casual user except the actual windings...
My bet is somewhere, that starter model has been used on other bikes too.
The secret is to find which one!
Moderators: scotch
Time to create page: 0.121 seconds
