Electrical
Honda AW82 coil fitment
- coleface
- Senior Member
8 months 4 weeks ago - 8 months 3 weeks ago
I re fitted my 1980 KZ1300 with the AW82 coils a few years ago and the bike ran well with them. I then removed the head and did some work. I am now re installing the coils and the RH one, for cyl 1 and 6 wont fit due to hitting the upper radiator hose. I don't recall this being an issue when doing the initial install but then it was about 7 or 8 years ago. Any ideas as to what I'm doing wrong. Is it possible to put the top rad hose on wrong? Thanks
Last edit: 8 months 3 weeks ago by coleface.
- Jafsteph
Re: Honda AW82 coil fitment
I am running them coils on my bike and it is close to the top hose
- poptheclutch
- Junior Member
6 months 3 weeks ago
I learned a little trick today while putting my coils back on. It's way easier to put the right coil on before the left. I know it sounds weird but it works for me. If you put the right coil on first, you can kind of rotate the studs in from the left side. Also having the air chambers off really helps.
The following user(s) said Thank You: KZQ, Kawboy
- poptheclutch
- Junior Member
Also right coil is supposed to be for #2 &5, top /center is for 1 &6. Guess it really doesn't matter as long as you get the primary wires plugged into the correct coil.
- kawaBCN
6 months 3 weeks ago - 6 months 3 weeks agoCompré mi juego de bobinas en SQUARE Motorcycle Parts.poptheclutch post=34216 userid=3320Además, la bobina derecha debería ser para los cilindros 2 y 5, y la superior/central para los cilindros 1 y 6. Supongo que en realidad no importa siempre y cuando conectes los cables primarios a la bobina correcta.
Me equivoqué al cortar la longitud de los cables de la bobina para los cilindros 1-6 y tuve que cambiar su posición para que los cables llegaran a las conexiones de las bujías.
(Google Translate) I made a mistake when cutting the length of the coil wires for cylinders 1-6 and had to change their position so that the wires reached the spark plug connections.
RUN LIKE THE WIND¡¡¡
Last edit: 6 months 3 weeks ago by Kawboy.
Moderators: scotch
Time to create page: 0.166 seconds
