Electrical
No lights runing
- ninja
- New Member
Re: No lights runing
12 years 1 month agoGood point... I've cleaned only the switch on the dashboard... not the one on the side... will try to clean it... thanks!roadhazard wrote: Check the main switch behind the left side cover. It's an anti theft switch. Cuts off power to the ignition. Mine did the same thing. Cleaned it with some contact cleaner and that fixed it.
- ninja
- New Member
I will clean that switch, never cleaned it... thanks!
- ninja
- New Member
How should I disassembly the main swirch behind the left cover without breaking it?
- Toddh
I have not looked at this switch for some time but see if there is a hole on the body of the switch. Attempt to spray some deoxit (electrical contact cleaner) from the outside.
In other words, try the least intrusive way first.
While its off the frame, I would take a look at, and spray the connectors on both sides of the harness.
Then take a volt/ohm meter and test it per the shop manual. This will be the most conclusive test to see if the switch is passing the continuity test.
Regards.
Todd.
Regards.
Todd.
KZ1300 A-4 4TH 1300 IN 30 YEARS
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
The following user(s) said Thank You: ninja
- ninja
- New Member
Moderators: scotch
Time to create page: 0.164 seconds
