kz1300 banner
Electrical
No lights runing
  • ninja
  • ninja's Avatar Topic Author
  • New Member
  • New Member
No lights runing
12 years 1 month ago
#3159
My bike wasn't running for about a year or so, i bought a new battery but the bike has no current on the board, or lights... but closing the circuit of the ignition solenoid the starter runs... where shouldI start looking for the problem?
Pd: sorry about my english, I'm from Argentina and I'm new in the forum
  • Toddh
  • Toddh's Avatar
Re: No lights runing
#3160
Start by looking at your fuse panel
T.
KZ1300 A-4 4TH 1300 IN 30 YEARS
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
The following user(s) said Thank You: ninja
  • ninja
  • New Member
  • New Member
#3176
I check at the fuse panel under the seat... all fuses work great...
But still no current or lights working... :(
  • RickG
  • RickG's Avatar
#3177
Have you used a meter to check the fuses. I have found many fuses that are not blown but because of age no longer conduct any current.
Is the main key turned on?
Z1300 A1 x 2
  • roadhazard
  • roadhazard's Avatar
  • Junior Member
  • Junior Member
#3180
Check the main switch behind the left side cover. It's an anti theft switch. Cuts off power to the ignition. Mine did the same thing. Cleaned it with some contact cleaner and that fixed it.
1980 Kz 1300 b2 touring
1980 kz 1300 A2
  • ninja
  • New Member
  • New Member
#3203
RickG wrote: Have you used a meter to check the fuses. I have found many fuses that are not blown but because of age no longer conduct any current.
Hhhnmm... I've just visually checked... will check them with a multimeter... thanks!
Moderators: scotch
Time to create page: 0.164 seconds
