Electrical
Starting problems / kz1300A
- RickG
Re: Starting problems / kz1300A
12 years 1 month ago
You can also get a manual here
www.dropbox.com/s/b5780fp1xj53o9s/Z1300%...i%20Manual%20opt.pdf
Z1300 A1 x 2
Z1300 A1 x 2
- Perucho
- New Member
Hi, BIGGER problems! 2 cylinder out - no pressure
- RickG
Check the valve clearances before you start to pull it apart to fix it.
Z1300 A1 x 2
Z1300 A1 x 2
- Perucho
- New Member
- Toddh
If it's not too late, perform a cylinder leak down test on each bore, before you tear it down.
A simple compression test will tell you one thing. if you do the leak down test, it will tell you if it's the rings, valves, or both.
You can pick up a leak down test set relatively cheaply at a local tool supply Co.
If there is more than 30K on the odometer, I would probably do the whole top end. If the rings prove tight and are serviceable, I might do just the cylinder head. That would depend on what the leak down test reveals.
Keep us posted.
Todd.
Keep us posted.
Todd.
KZ1300 A-4 4TH 1300 IN 30 YEARS
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
- Perucho
- New Member
Hi, leak down test done and cylinders 1 and 6 totally out of order. I even poured some liquid over the piston and it went right trough.
Perucho
Perucho
Moderators: scotch
Time to create page: 0.161 seconds
