kz1300 banner
Electrical
Starting problems / kz1300A
  • Perucho
  • Perucho's Avatar Topic Author
  • New Member
  • New Member
12 years 1 month ago
#3188
Hi, I need help with my Z. When trying to start the engine the yellow/blakc wire from the IC igniter starts to burn. Double checked every connection, nothing.. Renew the wire from the battery also.. Igniter dead? Should it be grounded seperately somehow? The frame was repainted..
Turn signals dead too.
  • Toddh
  • Toddh's Avatar
Re: Starting problems / kz1300A
12 years 1 month ago - 12 years 1 month ago
#3191
Hello Perucho:
You'll need to take a volt/ohm meter and start looking for a dead short somewhere, either in the main harness, a sub harness, or component.
Start with the wiring first, then use the shop manual to verify the pick-up coils, igniter, and ignition coils.
Make sure you do this with the wiring diagram out of the shop manual
Are you blowing fuses?
Regards.
Todd.
KZ1300 A-4 4TH 1300 IN 30 YEARS
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
Last edit: 12 years 1 month ago by Toddh.
  • Perucho
  • New Member
  • New Member
#3192
Hello Todd,
BIG ground problem. Attached picture of the main ground wire. First problem solved, still does not start.
No fuses blowing. I dont have the shop manual..
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
#3193
Perucho wrote: Hello Todd,
Hi Perucho,
Welcome to KZ1300.COM!
You can down load the service manuals from this site. They're on most pages at the upper right corner.
Bill
The following user(s) said Thank You: Perucho
  • Toddh
  • Toddh's Avatar
#3200
Yup, that ground looks compromised.
T.
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
  • Toddh
  • Toddh's Avatar
#3202
On another note, are you sure your side cover switch is in the ON position?
To be on, it must be in the horizontal position.
T.
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
Moderators: scotch
