Electrical
NGK Spark Plugs
- BigSix
NGK Spark Plugs
11 years 11 months ago
Hi guys
what heat-grade do you use in your zeds ? I noticed the manufacturer recommends to use the B(P)R 6 ES, however are you satisfied with the 6 as heat-value or do you use even 7 or 8's ?
regards,
Holger
regards,
Holger
Z1300 A1/ KZT30AG built 1979
frame KZT30A 004285
engine KZT30A 000288
frame KZT30A 004285
- RickG
Re: NGK Spark Plugs
6 is the right plug with maybe 7 in a very hot climate like 40°C consistently and 8 never need them and never use them.
Z1300 A1 x 2
Z1300 A1 x 2
The following user(s) said Thank You: BigSix
- kza13
Re: NGK Spark Plugs
I got 6 of those Iridium plugs, great plugs, fires up good and runs well
Frame No: KZT3OA003911
Engine No: KZT3OAE004153
- BigSix
Re: NGK Spark Plugs
I did raise that question in the UK forum, too. Seems there is a printing error in the manual.
The correct one, according to most sources, are the NGK B(P)R 6 ES.
Guess that sorts it out,
cheers,
Holger
cheers,
Holger
frame KZT30A 004285
frame KZT30A 004285
The following user(s) said Thank You: fabiodutra
Moderators: scotch
Time to create page: 0.247 seconds
