kz1300 banner
Electrical
Not switching off
  • Dinosaur
  • Dinosaur's Avatar Topic Author
  • Junior Member
  • Junior Member
Not switching off
11 years 9 months ago
#4213
Hi to all,after replacing the fusebox the bike does not switch
off with the ignitionkey.
She is starting,running and charging perfectly and after pulling
the main fuse while the engine is running the lights go dimmer
but the engine runs on.I have checked with a multimeter and
found there is batteryvoltage on both the positive and the
negative of the ignition coils when the ignitionswitch is
in the on position.
Is that how it should be?Without the mainfuse when engine
is not running there is no lights on dashboard.The only
way to stop the engine is to run until fuel is empty
Please help
Paul
Moderators: scotch
Time to create page: 0.161 seconds
