kz1300 banner
Electrical
Charging circuit diagram ? extra wires
  • aus_z1300
  • Topic Author
  • Elite Member
  • Elite Member
11 years 8 months ago #4781 by aus_z1300
Charging circuit diagram ? extra wires was created by aus_z1300
I was fitting a rear brake switch today and noticed a blue wire with an exposed end coming from the engine in the same bundle as the 3 yellow to the regulator rectifier. I searched a few wiring diagrams and could only find ones with the 3 yellow wires.
Mine is an a5 z1300. Does anyone know what this wire is for or have a diagram.
There are two other wires floating about that it could plug into but one has a blue with white stripe and then a brown one wich is on the reg plug but goes nowhere.
11 years 8 months ago #4782 by Toddh
Replied by Toddh on topic Charging circuit diagram ? extra wires
The blue wire may be to your fuel solenoid valve, that is the only blue wire in that vicinity. Up to the A-5, I too only see the three wires coming off of the Sub-alternator on that side of the crank.
Regarding the brown wire, and blue/ wht wire, it too may be fuel solenoid valve related. Take a look on page 369 of the A-5 supplement. It goes to the Reg/Rec.
Have you or someone disconnected that valve, may explain the disconnected wires???
What country of origin is your bike?
Regards.
Todd.
KZ1300 A-4 4TH 1300 IN 30 YEARS
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
  • zed_thirteen
11 years 8 months ago #4785 by zed_thirteen
Replied by zed_thirteen on topic Charging circuit diagram ? extra wires
I think the wire from the oil pressure switch is a blue wire. Don't think it is normally run through the same sleeve as the alternator wires though.
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
The following user(s) said Thank You: aus_z1300
  • aus_z1300
  • Topic Author
  • Elite Member
  • Elite Member
11 years 8 months ago #4787 by aus_z1300
Replied by aus_z1300 on topic Charging circuit diagram ? extra wires
It is odd it is an australian model i just found wiring diagrams in the back of the owners manual that came with it and it doesn't have the extra wire either.
11 years 8 months ago #4789 by Toddh
My 82 being an A-4 (U.S.) model has no extra wire in the sub-Alternator Harness.
This doesn't help your cause at all but someone may have added that wire over the years, as they could have replaced the stator on that side of the bike.
Or it could have been something done during the course of production by Kawasaki for the A-5, Z13.
T.
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
  • aus_z1300
  • Topic Author
  • Elite Member
  • Elite Member
11 years 7 months ago #5168 by aus_z1300
Found out what it was it's for the oil switch it just shares the stator outer covering and exits before the stator to the switch .
If you look at the parts microfish you can see it in the diagram on the a4 as well.
Moderators: scotch
Time to create page: 0.114 seconds
