Electrical
Pickup Coils
- Dinosaur
- Junior Member
Pickup Coils
12 years 7 months ago
Hi all.anybody know what pickup coils can replace the ones on 79 KZ? Found the one for no:3+4 dead.
Paul
- strate6
Re: Pickup Coils
Hi,
I am sure you may have checked, but have you tried swapping them around & also the wiring from the unit itself into the CDI Unit, as they often corrode & stop the signal.
I have never known one Pick-Up ever fail, it has always been a wire problem.
I do not think they are shared with any other models.
They often come up on Ebay.
Pete
Pete
The following user(s) said Thank You: Dinosaur
- zoso
Re: Pickup Coils
Hi
Double check the coil as well and spray all the connections with DeoxIT.
Billy
Billy
- scotch
Re: Pickup Coils
Is there a bike wrecking yard near you? MANY years ago one of my pick-up coils on my '80 1300 failed. I found a replacement from another Kawasaki in a bike salvage yard. It's lasted some 25 years ! I didn't make any notes as to which yr/model bike I scavenged from but my point is: A salvage yard could be a viable option.
Always High - Know Fear !
- Dinosaur
- Junior Member
Re: Pickup Coils
Thanks Scottch.I did find a complete set at a salvage yard,luckily the owner are a senior guy who do know the older bikes.
Paul
- GrooveM
- New Member
Re: Pickup Coils
I'm a little late to the party but I replaced my 1980 KZ1300B coils with Nology Pro-Fire PFC-30D's. I had to make custom brackets to mount them in the same location but they are terrific and I would recommend them to anyone. They run about $70-$75 a piece for the dual output version. Later.
www.nology.com/profiremotor.html
Moderators: scotch
Time to create page: 0.164 seconds
