- Thank you received: 21
Electrical
Stator fitment replacement a5 z1300 Help needed
- aus_z1300
- Elite Member
11 years 7 months ago - 11 years 7 months ago #5085
by aus_z1300
Stator fitment replacement a5 z1300 Help needed was created by aus_z1300
I need help with the stator test procedure i have downloaded a manual but that section is missing.
It does show continuity to ground which from what i could find means it is stuffed wich i would like to confirm.
When looking for a replacement i had trouble they mostly say they fit from 79-81 .
I looked up the parts schematic and a4-a5 stators appear to be a different part number as well.
Last edit: 11 years 7 months ago by aus_z1300.
- aus_z1300
- Elite Member
11 years 7 months ago - 11 years 7 months ago #5086
by aus_z1300
Replied by aus_z1300 on topic Stator fitment replacement a5 z1300 Help needed
To answer my own question if it shows continuity to ground it is stuffed.
So i thought why not have a look further into it the things buggered ayway.
See the pic where the 3 yellow wires come out there are basically 3 seperate enamelled wires wrapped around the posts.
They are all joined together at the other end.
As you can see in the pics i disconnected them and tested them individually and one of them is going to ground wich drags all 3 to ground when they are connected.
And if you look closer you can see the burn't looking coating that is the one that is on the circuit shorted to ground .
- kwak1261
- Thank you received: 63
11 years 7 months ago #5143
by kwak1261
Z1300 A4 ZG1300 DFI X2
Z1261J GS1000S
Vmax1200 XT500
Replied by kwak1261 on topic Stator fitment replacement a5 z1300 Help needed
that looks crispy
look here for an upgrade replacement
www.electrexworld.co.uk/acatalog/Online_...e_Generators_32.html
Z1261J GS1000S
Vmax1200 XT500
- aus_z1300
- Elite Member
11 years 7 months ago #5144
by aus_z1300
Thanks i seen that today i couldn't find one the same as mine do you know of one that is definetely going to fit mine seems to share the same part number as the a4 And i have contacted several sellers nobody does one the same.
- kwak1261
11 years 7 months ago #5150
by kwak1261
Z1261J GS1000S
Vmax1200 XT500
In the top line G03 says its for a Z1300 injection, should fit yours.
Z1261J GS1000S
Vmax1200 XT500
- aus_z1300
- Elite Member
11 years 7 months ago - 11 years 7 months ago #5166
by aus_z1300
Mine must be an odd one i have tried everywhere .It measures 105mm outer 38mm center and 25mm thick across the center shares the same part number as the a4 one .
I have had a go at repairing mine . I cut and unwound the the shorted coil Then cleaned up the post a little with the die grinder coated it in a two part liquid metal. Then i bought some new enamelled wire from jaycar and rewound it joined it up again all tests are fine so i replaced the exposed old yellow wires that were brittle and hard with some new ones .
Then coated the whole thing in araldite . Going to fit it today and see what happens .
Moderators: scotch
Time to create page: 0.128 seconds
