kz1300 banner
Electrical
Dyna coils
  • Ager
  • Topic Author
  • Senior Member
  • Senior Member
11 years 5 months ago #5665 by Ager
Dyna coils was created by Ager
Hi i am very close to firing up my 13 after a three year rebuild i have just received some dyna coils should i dump the ballast resistor when i install these
11 years 5 months ago #5666 by fastpapaw
Replied by fastpapaw on topic Dyna coils
I recently installed the Accel coils which are also 3 ohm. The instructions specifically say DO NOT use the ballast resistor.
Mike
'79 KZ1300, '74 Water Buffalo, '82 GS1100, '99 Ducati 996, '95 Goldwing, '13 BMW R1200RT, '13 ZX14R, '06 YZ450F Supermoto
The following user(s) said Thank You: Ager
  • zed_thirteen
11 years 5 months ago #5667 by zed_thirteen
Replied by zed_thirteen on topic Dyna coils
If they are the green 3 ohm Dyna coils then you need to get rid of the ballast resistor
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
  • LareNurminen
11 years 5 months ago #5672 by LareNurminen
Replied by LareNurminen on topic Dyna coils
Best be safe and check the ohms on the primary side from each double coil. Turn your multimeter to the lowest ohm rating and connect the wires to the flat connectors on the coil.
If the reading is 3 ohms +/- 0.5 ohms, you are OK. When getting rid of the ballast resistor, just connect the three cables coming out of the white resistor block to the single in feed of the resistor.
Merry Xmas from Finland
  • Ager
  • Topic Author
  • Senior Member
  • Senior Member
11 years 5 months ago #5680 by Ager
Replied by Ager on topic Dyna coils
Yes they are the green 3 ohm coils so i think it is best i do not connect the resistor have read it can fry the cdi unit with it in place
Moderators: scotch
Time to create page: 0.120 seconds
