Electrical
Nology Profire PFC-30D Coil Mounting Brackets
- spanna
- New Member
11 years 5 months ago - 11 years 5 months ago
Here is some info regarding the brackets I made to fit Nology Profire PFC-30D Coils.
These coils fit well and work well. If anybody finds any problems with my document
please let me know so that I can fix the document. I have done a PDF document to help
with printing.
with printing.
Last edit: 11 years 5 months ago by spanna. Reason: Change Attachment size
- kennyb
- spanna
- New Member
Re: Nology Profire PFC-30D Coil Mounting Brackets
No I am not selling these brackets, this is to show how I made some brackets using some 25mm x 25mm tubing with some flat bar and a few nuts and bolts (some taken off the old original coils).
FYI the Nology coils can be purchased here www.nology.com/profiremotor.html
- rob
- Senior Member
If you make them I will pay the cost if it is reasonable.
- Medlock1
- New Member
11 years 1 month ago
Thank You Spanna.
I'm headed the same way and yours is cleaner. Only nagging thought is with the coils laid over versus hanging would you be concerned with vibration or a few deep potholes cracking the coil housing? I was going to put the two on top (same orientation you have) and support the coil body with thick rubber.
Thanks, Louis.
Thanks, Louis.
- rob
- Senior Member
My brother and I have been using these coils with the same brackets for about 4 years now and have not had a problem at all. They fit in easily and are not a problem removing to take the valve cover off.
Moderators: scotch
Time to create page: 0.177 seconds
