- Thank you received: 8
Electrical
Dual stator wiring
- kennyb
11 years 4 months ago - 11 years 4 months ago #5893
by kennyb
Dual stator wiring was created by kennyb
Just added a sub alternator to my A1. So do I need two regulators ?Or do you wire the extra stator into the existing voltage regulator? If so do you wire it to the stator out put AC side or out put DC side on the regulator? BTW The sub alternator was sourced from a Voyager 1300,thanks.
Last edit: 11 years 4 months ago by kennyb.
- kennyb
11 years 4 months ago #5969
by kennyb
Replied by kennyb on topic Dual stator wiring
Anyone?
- RickG
- Thank you received: 92
11 years 4 months ago #5971
by RickG
Z1300 A1 x 2
Replied by RickG on topic Dual stator wiring
I have not ever fitted one but my thoughts are that a complete second system including regulator would be needed you couldn't hook them together because you might to have one feeding the other and end up with nothing where with a second system they both see a battery that needs charge or lights that need power and deliver it.
Z1300 A1 x 2
- LareNurminen
- Thank you received: 153
11 years 4 months ago #5972
by LareNurminen
Replied by LareNurminen on topic Dual stator wiring
If you have a service manual which covers the -82 model, you will have at the end the schematic which shows how Kawasaki did it.
My 82 has originally two alternators, both have their own reg/rec and they are connected to the main harness.
Hope this helps,
Lauri
Hope this helps,
Lauri
- trikebldr
- Thank you received: 37
11 years 4 months ago #5976
by trikebldr
Replied by trikebldr on topic Dual stator wiring
FWIW, the ZN1300 supplement manual show the two alternators, each with it's own rectifier/regulator, but the wiring harness connects the two together as Lauri said.
- kennyb
11 years 4 months ago #5977
by kennyb
Thanks people! Okay that's what I thought
Just wanted to be on the safe side before I created a firework show in my garage or between my legs at 70 mph :ohmy: Thanks
Moderators: scotch
Time to create page: 0.119 seconds
